Conversion U-joints Strength?
  • Conversion U-joints Strength?
    Im having to run two 1350 to 3r conversion joints with my new drive shaft I can only buy the conversion joints in the greasable type. I know the grease type u-joints are suppose to be weaker then solid u-joints has anyone broke any of these running them in there cars? My car is around 400rwhp and is a m6 will they hold up well?
    01 NBM Base SS build #514 M6 Pat G/EPS 230/234 111+4 Cam, LS2 Heads, Tick Master,Extreme Chassis 8.8 with 4.30's, BMR LCA And Torque Arm, Edelbrock PHB, FIPK intake, Ported TB. Jet-Hot LT Headers TSP True Duals Tuned By SB Tuning
    They are stronger than the stock driveshaft
      I'm running one as well.
        Me too.
        -Homer Simpson
          me 3 ds broke before that did lol.
          97 TA AI 355
          2012 Jeep Patriot
            Well I'm running one on the front and back I hope they hold up I'm running a steel driveshaft so I doubt the driveshaft is weaker then them.
            Does anyone know if the stock steel ls1 driveshaft is 3inch around like the aluminum one?
              do you mean the stock lt1 ds? if so no its smaller dia.
              97 TA AI 355
              2012 Jeep Patriot
                No I mean the steel ones that came on ls1 with 2.73 gears.
                I got a 3inch steel driveshaft with my new rear and I'm wondering if its a stock one or not. Its ballanced and has 3r ends
                  wow i didn't know they they came with steel ds..
                  97 TA AI 355
                  2012 Jeep Patriot
