broke? could have drove it all year
"normal" operating temps for a stalled 4l60e
might as well just write a computer program to drive the car and watch from the standsOriginally posted by ThreeHonks View Postyou proved my point. consistency. and less breakage.
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
Interior Whore
- 6380
- fred
- 1996 Camaro z28
No! Most of it was getting the stall speed and torque multiplication ratio right from the mess that is was, then the cooler. See ya tonight!Originally posted by ThreeHonks View Posttotally depends on what cooler you choose to run.
My trans ran at about 165-170 but most of that is because of my large and very efficient cooler mounted in front of the radiator. 200* wont hurt anything, but the cooler the better. Ideal spot for a temp gauge would be on the line that flows into the cooler.
Yep see you tonight mike! so are you saying 200* is too hot for a trans? or are you saying that once you changed the converter around, that was the cause of it being much cooler?Originally posted by Ridings Automatics View PostNo! Most of it was getting the stall speed and torque multiplication ratio right from the mess that is was, then the cooler. See ya tonight!
Originally posted by JoeliusZ28 View PostRight, but core temp has just as much to do with parts failure as fluid temp imo.
I'm not saying i disagree with putting it in the line, thats fine, but Im not seeing the point of the arguement on tech. I see a bunch of: 'The pressure port doesnt give you an accurate reading of fluid' ... so what? thats like asking what fails first, the main bearing or the oil? If one is hot, so is the other.. and if it isnt it will be very soon.
If you really wanted to be "Anal" as some guys i believe are mistakenly putting it... you would be looking for a fluid temp AND a core temp and averaging those values out.
The gauge in either location is going to give you an IDEA of what is going on in the trans which is the purpose of having it in the first place. If 10-15 degrees and a little variation really matters, then you should be at the GM proving grounds instead of LS1tech.
The statement that the pressure port doesnt variate is also false. My truck with the sensor in the test port and a stock trans, stall, etc would see temperatures all over the place during summer months depending on the driving conditions.
I did work at hydramatic at the proving grounds, although you were only 4 at the time i was working there. Anyways, you are right about the temp variations. In a stock application there is a minimum 10 deg varance between engine coolant temps and trans temps. The stock pressure port is a decent location for a temp gauge with 1/8 npt. It's more of an indication of working temps. The sump temp just tells you how hot the pan fluid is. The best place for a gauge is on the cooler return line, but most people are not going to mount there.
Thru a run trans temps will go thru the roof, but if you can average 185 your doing awesome.Originally posted by ThreeHonks View PostYep see you tonight mike! so are you saying 200* is too hot for a trans? or are you saying that once you changed the converter around, that was the cause of it being much cooler?
