Well I have a 2004r in my 83 and am going to be using a stock OD shifter, cause my mega shifter is incomplete I found out, so my question is
should the shift points on the shifter mechanism be the same for it as a 700 r4?
I have the stock shift linkage and I also have 2 aftermarket shifter cables, if the shift points are the same for the 200 and 700 I will use the stock linkage otherwise I can use an aftermarket cable..
I am not trying to confuse so if you need clarification please post..Any help would be great
