w/ winter coming, its getting to be time to start thinking about working on the fireturd again... Looking for some input on what to do to back half of the drivetrain...
Trans, few options here car is going to be used (mostly) on the 1320, but would like to do some AutoX s well..Plus cruising around now and then.
It currently has the 4L60(i think) in it, but I have been considering swapping to a M5 or a T56(if possible). TEP did the trans in my W, and Dave said he could do a build on the current trans for ~$1500-2k that will hold the power...
Rear end
really need input here... I wouldnt mind going to a LS1/LT1 Disc setup IF it can hold the power for a year or so to let me save to buy a proper rear end
Engine is going to be a boosted v6 (goals of around 4-500whp), and even though that may sound nuts, its fairly easy to get similar numbers in a Wbody with a milder build than what im going to do on the Turd...
Again, any input/experiences on the trans and rear would be greatly appreciated
Ill prob be doing a suspension thread later on, but for now I already have BMR CAs and subframe connectors, that plus the cage should stiffen me up a little from stock and help w/ handling a bit
Rear end
