something in my rear end is clunking pretty loud when turning all the way left, no matter what speed every tire rotation i get a loud clunk that kinda even shakes the car. the clunk is coming from the rear right tire area..
http://img291.imageshack.us/i/0712091048a.jpg/
that piece with the arrow going to it moves IN and OUT about 1/8th to a quarter of an inch..
I was told on ls1tech to remove the rear end cover and look for loose metal.. I did that and got this..
http://img440.imageshack.us/i/metalq.jpg/
now when pulling on the studs of the rear driver tire, with the cover off i can see movement in the rear end where the arrows point in this picture, if i look in that hole while someone is pushing and pulling the stud/axle shaft thing i can see it movin
http://img404.imageshack.us/i/rearend2.jpg/
I was told on ls1tech i most likely either need new bearings and seals or an entire new differential..
-Now in the previous picture where its circled, i removed that cover to the bearing..
http://img248.imageshack.us/i/coveroff.jpg/
I'm not to familiar with these rear ends so im kinda stuck on what to do now to finish removing the axle shaft, do i need to remove the spider gears then remove the c clip or?? any help is appreciated!
and is their a certain brand of fluid i should use?? whats the proper fluid to use??
thanks..
edit: im tryin to get this done in time for the meet and greet this weekend!!
thanks..
for ya.
