my clutch has a little play in the end of it and its making a very very small grinding noise. i thought it was the throw out bearing. but the i called the guy i just bought it from and he told me he put a new on in it. and the slave/sleeve cylinder needs to be bleed to stiffen it up.
so how do i bleed the slave/sleeve cylinder
thanks. im not sure which one its called.
HISTORY OF CARS PAST AND PRESANT (none of them were wrecked)
1989 S10 standard with 350 carb'd, th350, shift kit, shorties, 600cfm, hooker TD's, 3.23 non posi, B&M shifter(sold)
1991 firebird with t-tops and 3.1L, 700r4, 3.23 non posi, flowmaster cat back, 15ibs injectors, (sold)
1991 formula with t-tops, WS6, 5.0TPI, WC T5. 3.42 posi. magnaflow cat back, 52mm TB, and hurst billet (sold)
1994 camaro z28 with t-tops, 5.7LT1, T56, 3.42 posi. CAI, elbow, Airfoil, SFC, STB, pro 5.0, flowmaster cat back. (sold)
2000 Trans am with t-tops, 5.7LS1, T56, 3.42posi, LT'S, ORY, magnaflow, lid, lingenfelter intake, 3pt SFC, STB, LCA, (current)
^^^ yup, some people even go as far as to attach a small rubber hose and submerse the open end in brake fluid in order to only allow the air to escape the line. Make sure you have somone to press the clutch down slowly as you do this too. Good luck
sigpic 2002 Camaro v6: Cobalt metalic blue "Blue Devil"
