Ok my kids 97 V6 camaro started leaking a little oil, looks like either the front of the oil pan or the front seal. Anything GOOD out there to add to the oil to stop this from leaking? I've used different cheap additives in the past on other daily drivers but nothing seamed to work. Anything out there anyone can recommend that will/might work? Thanks 68rs383
1997 V6 camaro Oil leak
dont have any suggestions for you but i have heard that oil leaks on the RWD 3800 are a pretty common problem unfortunately
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
There is nothing that will heal a front seal other than replacement. Nice weekend project to bond with your kids.sigpic
rear main seals usually are the ones that leak. From the front I am not familiar with anything commonly leaking from the front. It is always the rear.------------------------------------------
5th gen Camaro V6 Forums
http://www.bowtiev6.com
InActive Member- April 8th, 2008
- 34
- Gearhead
- 1969 Camaro, 1979 Camaro, 1981 Camaro, 1983 Firebird
- Pittsburgh, PA
You can try a cap full of brake fluid in the oil and it should swell the seals. At worst it does nothing. At best it fixes the leak(s). Even better, it fixes the leak and gives just long enough while frying the bearings to build another engine and give an excuse to add more power
you mean oil leaks on any gm v6 is very commonOriginally posted by JoeliusZ28 View Postdont have any suggestions for you but i have heard that oil leaks on the RWD 3800 are a pretty common problem unfortunately
Sold!
www.fquick.com/lozanoa11
94 Grand Cherokee (sold)
95 Accord(for sale)
99 Outback (snow destroyer)
