it will accerate quicker but yes you will loose MPG's b/c it will be reving higher all the time. however with a v6 i am pretty sure 4.10's will be way overkill and you will be better off with a 3.42
and 4.10s are not overkill on a v6 depending on the setup.
but yes changing gears will lead to needing it tuned for them. With your 96 car, you would then need a 97 pcm as well to be able to tune it as the 96 pcm is not tuneable. A 97 pcm is a direct plug in play pcm
If you do any gears a 3.73 in a stock 10 bolt is prime.
3:73 is a great gear to go with, its one that you really cant go wrong with if you leave the car the way it is or even do some kind of mods to it. I really want to swap my rear out for a POSI disc rear end with 3:73 gears... I think you would be happy with those and you will notice a difference from you 3:42's
ok thanks alot guys i guess i will go 373 sounds like a perfect medium and with this car i dont really plan on turboing it if i want to go that hardcore with it i will probably just buy a v8 but thanks alot guys you have all been a ton of help
remember going 3.73s you are going to need to tune the pcm for it. Or your speedo will be off and rack up more miles than you really are. And shift points will be off
so you better start looking for a 97 pcm then if you are going that route
