trans difference
  • trans difference
    what is the difference between the auto trans in a 94 camaro with a v6 and a v8 arent they both 4l60e?
    I've never heard a full real explanation on this, just that it was necessary to do.
    Obviously, the torque converter will be different. Same with the bell housing I think? I dunno, hopefully someone else can jump in. Mike Ridings would probably know.
      Are the in/out shafts the same I would imagine the V6 model trans would have less splines and a lower torque capacity
      01 NBM Base SS build #514 M6 Pat G/EPS 230/234 111+4 Cam, LS2 Heads, Tick Master,Extreme Chassis 8.8 with 4.30's, BMR LCA And Torque Arm, Edelbrock PHB, FIPK intake, Ported TB. Jet-Hot LT Headers TSP True Duals Tuned By SB Tuning
        i havnt looked at any of that but i have a v6 trans that maybe has 1500 miles top. could you use some of the parts from that trans to rebuild a v8 trans.
          I just went through this. Sell it and buy a v8 tranny. They have different converters, bellhousings, input shafts, stater tubes, and can't hold the power. I wasted to much time trying to make it work. I'm just having mike ridings build me a v8 trans, should be done here any day now actually.
            i already have a v8 trans so ill just use it i was just wondering becuase my v6 trans is pretty much brand new. thanks
