When I was changing out the u-joints on mine (aluminum) I had to use some Large amounts of brute force and heat to get the factory u-joints out. Now at higher speeds (50mph+) I feel a vibration as if the u-joints were bad.
Since the u-joints that are in there are new is there a possibility that I may have bent the holes on the driveshaft or the yoke in just enough to make it funky... Oh and I've changed u-joints many times before and have never had a problem.
Is there something a driveshaft shop could do or should I buy another used one...
