My bet is your axle is in need of some attention.
Either pinion bearing or adjustment / rebuild.
I'm pretty sure that is my vibration also.
I thought for sure it was u-joints, but i took it to the shop and they said the u joints are perfect but were the axle connects to the rear end, you can move the rear end piece around in a circle or egg shape....
I would look at this on your car asap, as it most likely is the problem, if you have the stock 10 bolt in it.
