Now I'm mad
  • Now I'm mad
    I put 868.08 in to the trany and flywheel and my car still has that vibration
    A good thing is I can go about 70 now so as long as I'm in the back of the line for the M&G I can keep up
    Anyhow, not sure where to go from here
    hows the drive shaft?
      The drive shaft was balanced last year as well as new tires.
        Clutch off balance? Polly transmission mount?
        www.BroughtonAutomotive.com
        www.fquick.com/Camaro_Driver_19
          Always worthwhile to check and make sure it didnt throw a weight
          also:
          check ujoints for any binding
          rotate tires or cross them to see if it changes - possible broken belt
          check for axle runout
          check rear axle alignment
            also:
            all Good things too Check
            Do you have a Adjustable torque arm? If you do check to see if the Pinion Angle is correct. With a stock arm this should not be a issue.
            — Thomas Jefferson
              also:
              U-joints are free rolling
              Have to do the tire thing but they were new last year.
              Have to do the last 2 yet
              Torque arm is UMI Ajustable and the angles are right
                Man Kyle...that's bad news! I wonder what's going on there....seems like you have went over every possible thing since last year that could cause this vibration.
                Maybe you should sell the car to me for say $1500
                  Now why would you want a LT-1 car when you have a bad LS-1 3rd gen
                    ya rly.
                      Everybody needs a beater to cruise around in.
                      — Thomas Jefferson
                        That must be why you own a Camaro
                          Actually thats why I own a cutlass.
                          — Thomas Jefferson
                              ohhhh sick burn.. lol
                              thats sucks kyle..
                              don't worry, at least yours runs.. starter went out on me in Raleigh this morning.. 220 tow bill................
                              -Im Ron Burgundy?
