Dropping Rear End
    Originally posted by Iroc'nthe87 View Post
    What bearings?
    Scratch that last part about bearings, im out of it today
      Originally posted by 86Camaro View Post
      wheres the pin located exactly?
      look at the gear assembly where the 2 red springs are there should be a big metal pin in place you have to remove it
        remove the bolt by the arrow then slide the pin out. then pry the springs put. next push in on each axle and remove the c clips from were you just removed the pin from
          but to get the axles out there is 2 c washers in there. push the tires in reach in roll it slowly and you should see a washer that will slide out once that is out you can pull the axles free.
            With the rear supported remove you tires.
            Remove your rear breaks unless you have drums then pull the drums off.
            This will exspose the axel hub.
            In the pic is the pin you need to remove and there is a small screw that holds that pin in. You need to rotate the diff till you can get at the screw that holds the pin in and remove it.
            This will let the pin fall out.
            Now if you push in both your axels you should hear a clink sound, it's o.k. that's the C-clips falling off.
            If you don't hear a clink the you will have to pull the C-clips off then you can pull both axels out.
            Now don't rotate the gears after you pull the pin out or your spider gears will fall out and you will have a mess.
            Best thing is to putthe pin back in with the screw after the axels are removed so nothing falls apart
            Now you have 4 bolts that hold the diff in, 2 on each side.
            Remove them and teh diff will fall right out.
            YOu will have shims on each side, don't mess them up!!
            That is how your diff is spaced to your pinion.
            If you do a new pinion and gear set you will have to reshim it 9 times out of 10.
            Hope this helps.
              wow okay guys, well i went to school, so im back now but before i went i removed that big center pin, and little brother pin that secures it, plus i took something off idk what it is or if i was supposed to, what next?
                it was 4 bolts, and then these big C clips came off, that kind hold it all in i think, but its still all in held by the shaft
                    theres c clips that hold the axles in still you missed those
                    The LS1 or Go Home Crew
                    ASE master certified
                      Read it again
                      I layed it out for ya step by step
                      Hope this helps.
                        Where r the two C clips exactky?
                          inside where the red springs are or were
                            The C clips are on the end of the axle shafts.. you'll need to push the axles in to get em out..
                              ^ Yup, what he said
                                What does akll of this mean?? In the last pic there is only 1 rings that came off the right side compared to 2 on the left unless i lost it somewhere...is that normal??
                                What does all f this mean??
                                In the third picture of the smaller spindle thing im holding, it looks like it has been cracked off something, or it was longer..
