Drag rules on cages
    if it is a "factory" appearing car they don't seem to mind much. or look into things much. if you are that worried. run 1/8th mile passes and then on your last few runs of the day do your glory pass. but running 11's they probably won't care too much. shit i ran a couple 9 sec. passes and a couple 10 sec. passes coasting at lapeer and they never said shit to me. my buddy Joe ran the same car at milan and they booted him for not having a license to run.
    saftey is a good thing and having the proper equipement is good as well. but if you just want to go out and run a few times. i bet you won't be hassled with. i plan on going into the 9's this year and i don't have the $$ for a cage so i'm depending on 1/8th mile passes until i get the suspension squared away and then go for a full pass until they kick my ass out
    1998 Camaro SS Bullseye Turbo
      7.30 or faster in the 1/8 needs a 6 point
        Martin is a bugger!!!
        I almost got shot down because my batt. had just a slight bit of movement.
        They have always been tough on me every time I go.
        So acording to what you posted Larry, they can call Nitto DOT drag radials "slicks" if they want and turn you away?
          Martin has never gave me grief for my MT DR's.
          Wade
            I think I had nitto's on when Lapeer booted me for no bellhousing.
              I sure hope a firejacket isnt needed, or a driveshaft loop, my car should be into the 13s if I up the boost, and having a sc that is not stock...
              -Derek-
