v6 Rear end build or sawp?
  • v6 Rear end build or sawp?
    Well the car was a stock 3.4l V6 car. now a lt1 is under the hood. I no i need to up grade the rear in some way.
    It is time to work on the rear end. So do i just build up the stock durm 7.5 or buy a used z28 rear with disk?
    ALso did gm offer a 7.5 in the v6 car and a 8.5 posi in the v8 car?
    1993 Camaro
    th-400
    3.4 to lt1 swap
    stand alone wire harness
    coming soon ( just ask)
    home made S400 frount mount turbo on the way
    397ci 9:1
    Goal 750rwhp+
    The Y87 Cars had an upgraded rear axle but if I were you I would just buy a used one off a Z28 or TA. Depending on what happens this week, I might have one you could buy. But right now that is a last resort.
      well if you turbo project goes through you'll want a moser 12 bolt or 9" to handle that power.
        7.5 in all fourth gen fbody cars.
        5th gen Camaro V6 Forums
        http://www.bowtiev6.com
          if you're going to spend money on a rear end go with one of those choices, or an s60
          and they are all junk!
          ...the car/engine bay picture in your sig is actually finished, it's someone who ForceFed98 knows on ls1tech....
          1998 Camaro SS Bullseye Turbo
            Youll def wanna go atleast 12 bolt on this one, if not stronger. the 10 bolt in the birds stock are worthless for anything with drag radials on it, lol.
            Mods:
            Ram Air Intake (CAI)
            K&N Filter
            Polished Throttle Body and MAF Sensor
            De-screened MAF Sensor
            Tightened Throttle Body Cable
            Performance Button Setting Changed for Torque
            160* HypterTech Thermo
            Water Wetter
            New Distributor, Plugs, Wires
            New Water Pump
            LT4 Knock Sensor
            Flowmaster 40 Series Muffler
            TB AirFoil
              just by reading your sig... Goal 750rwhp+
              dont even think about having a 10 bolt...
              -Derek-
                See Sig
                V
                V
                Nick H.
                Current MIFC Vice President
                  Originally posted by 93formulalt1 View Post
                  See Sig
                  V
                  V
                  an aim convo i had this week:
                  JoeliusZ28: drag radials
                  JoeliusZ28: and i just bought another 10 bolt
                  sixspdzz28: whoamygod
                  sixspdzz28: 5k drop it like its hot
                    ever said that was my set up. just that is the same set up i am going with. frount mount s475 .
                    Also i would liketo bolt in a for 9 inch but at this point i no that i am not going to be making much power. maybe 550rwhp. at best. I still have a ton of work to do and i want to get the thing runing. i have seen 9 inch kits for my car but they are like 2k .
                    and what is a s60?
                    1993 Camaro
                    th-400
                    3.4 to lt1 swap
                    397ci 9:1
                    Goal 750rwhp+
                      the s60 is a dana axle i belvie, not positive tho, but a good dana rear end is bulletproof.
                      Mods:
                      K&N Filter
                      Water Wetter
                      New Water Pump
                      LT4 Knock Sensor
                      TB AirFoil
                        and what is a s60?
                        550 rwhp is too much for a 10 bolt assuming you have traction.
                        Im worried abotu breaking mine with no more than 300 rwhp
                          So you are telling me that. i i werh to buy richmound gears and pinon kit with some moser axles . that the rear 10bolt 7.5 would not hold 750rwhp?
                          plan B: 9inch ford
                          I would like to use a 9inch ford. I have to buy a custom driveshaft so y not?
                          1.
                          Well I was thinking a used 9inch ford . rebuild it and have it cut down to size.
                          2. buy a new housing , and tub kit. have it fabed to fit my car. then buy new axles and a used center section.
                          3. company with a prefad housing?
                          1993 Camaro
                          th-400
                          3.4 to lt1 swap
                          397ci 9:1
                          Goal 750rwhp+
                            plan B: 9inch ford
                            1.
                            GM gears are the strongest. Getting richmond gears would be a downgrade if it changed strength at all.
                            your best bet is to go with a 9" ford made for an f-body. The torque arm mount is not something that can be "fabbed" ...believe me ive looked into it, not happening.
                              Yep no 10 bolt will hold that much power.....ever. Hell they have a hard time holding 400rwhp in a manual car. As for rear ends look at spending at least $2200 but its an absolute must for that kind of power. Drive-line solutions has exactly what your looking for.
