Originally posted by ChevyCamaroRS97
Which Clutch???
if you run into any dilemma's during the install post up, I just did mine over the summer so its fresh in my mind-Joel
yea i did mine about a month and some change ago...so yea i remember very well!.... damn was it a learning experience for me!
1998 Camaro SS Bullseye Turbo
any updates on this endeavor?-Joel
Yeah- How about an update lol. I might need a new clutch soon, so any reviews for us?Nick H.
Current MIFC Vice President
- October 3rd, 2005
- 1027
- Mike Rhodes
- 1994 Chevy Camaro LS1 M6 Cammed
- Harrison Township, MI
- Technician, Moran Chevrolet
sry no updates yet. I have the clutch thats it I'll be getting back into shop on Tuesday so thn i stary tearing everything out so i'm in there 3 days a week for 2hrs and 40 mins a day so i hope to have it done in a week if not two.
It sux i've been waiting to get into shop again so badd i want to drive my car again. its been hard not having a car to drive.-Mike
Chevrolet Technician
Totaled 99 SS swapped drivetrain, harness, interior, and suspension into 94 Z28.
yea new clutches are a pain in the bum to put in...mostly removal and installing the trans is the pain in the bum bum!...hope it works out good!1998 Camaro SS Bullseye Turbo
- October 3rd, 2005
- 1027
- Mike Rhodes
Update
ok i just got home from shop i talked my teacher into letting me work on my own car during auto club, a club that meets after school on thursdays but normaly we can only work on our cars during class, but anyway i got the everything out didt realy come into any problems the only hard this was the two bolts on the top of the damn bell houseing. my clutch was pretty much a mirror it was so damn glazed. tomarrow im sending the flywheel out to resurface it it'll be back later the same day. then on tuesday, b/c im not back into shop tll then, i can put inthe new clutch and start ressambly. wow it soo much work just to get to it then it takes like 5 mins to put the new one in then u got to start putting it all back together. the only other thing im doing is put a new seal on the rear end were the driveshaft goes in and since i'll be taking it apart im gona also put on a new rear main seal. So far no borken blots no problems so "knock knock" i'll update as i get further-Mike
the fun part is yet to come if that tranny input shaft doesnt line right up with the clutch. (chances are it wont) get ready for some experience wrestling a tranny.-Joel
yeah lining that stuff up is tricky... i broke my brand new slave cylinder i had to "upgrade" to...so then i had to buy another one!.... oh and the rear pinion seal...watch out... that can mess up your gear lash if you just torque that nut on the crush seal with out check'n the lash. i had that replaced when the moron at the trans shop first put in my clutch...like a month later from the lash being off...my rear end blew!...so that's when i decided "F--- everyone else i'll do it on my own the right way" so that's when i replaced my clutch and did everything myself. had to get rear end re-built (3.73's went in
) and had my trans rebuilt by D&D perf.
anyways how is that clutch goin? and i hope your rear end doesn't mess up in a month or so from swapping that seal.1998 Camaro SS Bullseye Turbo
what are you talking about with this "lash?" would that be the source of my vibrating?Originally posted by SS4Mattyeah lining that stuff up is tricky... i broke my brand new slave cylinder i had to "upgrade" to...so then i had to buy another one!.... oh and the rear pinion seal...watch out... that can mess up your gear lash if you just torque that nut on the crush seal with out check'n the lash. i had that replaced when the moron at the trans shop first put in my clutch...like a month later from the lash being off...my rear end blew!...so that's when i decided "F--- everyone else i'll do it on my own the right way" so that's when i replaced my clutch and did everything myself. had to get rear end re-built (3.73's went in
anyways how is that clutch goin? and i hope your rear end doesn't mess up in a month or so from swapping that seal.-Joel
possibly...lash is the amount of "play" between your pinion and ring gear. when your rear end is put together brand new... the gears are where they are... they wear themselves into that spot. so when take the pinion nut off and replace that crush seal, and you just take an impact and put it back on...you will mess up that gear lash enough to make the gears not line up the way they did before. it's not a huge deal but because the gears are not lining up the same...they will "fail" much sooner than they should. when my gears blew...i was just cruising down I75 comin home from my friends school in midland. honestly goin like 75-80. nothing that is "stressful" on anything. and then all of a sudden i started to hear a gear whine...then it just got worse and worse. but the time i made it home...it sounded like i was dragging a boat ancre behind my car!1998 Camaro SS Bullseye Turbo
why would that have gotten messed with on a clutch install though? my car has 3.73s, and i can tell they were installed good. i have very little slack in the rear end, and no whine whatsoever practically - i have to concentrate on listening for it to notice it. i plan on unbolting the DS and rotating it 180 degrees and seeing if that helps.Originally posted by SS4Mattpossibly...lash is the amount of "play" between your pinion and ring gear. when your rear end is put together brand new... the gears are where they are... they wear themselves into that spot. so when take the pinion nut off and replace that crush seal, and you just take an impact and put it back on...you will mess up that gear lash enough to make the gears not line up the way they did before. it's not a huge deal but because the gears are not lining up the same...they will "fail" much sooner than they should. when my gears blew...i was just cruising down I75 comin home from my friends school in midland. honestly goin like 75-80. nothing that is "stressful" on anything. and then all of a sudden i started to hear a gear whine...then it just got worse and worse. but the time i made it home...it sounded like i was dragging a boat ancre behind my car!-Joel
