since i believe my axle is bad, whereabouts do i find replacements. the axle must be bad because after changing out bearings, the noise is still there and sometimes even seems louder.
where to find axles
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
- Electro-Mechanical Engineer
Ive got the number to the guy who just rebuilt my rear end, Im sure he can get what you need.
His name is Scott and the Name of his company is driveline solutions
586-218-7140
He's also a sponsor on LS1tech.comLast edited by SlipStreamZ28; August 8th, 2007, 06:09 PM.The Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
i only changed out the outside axle bearings, but forgot to pay attention to the axle. it sounds like its only coming from the passenger rear. i havent messed with the diff yet but would like to add some 3.73s.Originally posted by bmwmcars View Postwhat bearings did you replace? the wheel bearings? or the pinion, or?
is it gear whine? if so, that could be preload/lash issues with the diff.
if you are buyin a new diff, you want to stay stock or go to a 12bolt?sigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
- February 18th, 2007
- 2164
- Creight Smith
- 1999 Camaro SS / 1969 Camaro / 2011 Camaro SS
- Coloma Mi
How about a site sponsor?http://www.fquick.com/csmith4153
2011 Camaro SS
1999 Camaro SS #4153
1986 Monte Carlo SS
1969 Camaro - 427 Rat
- 2164
- Creight Smith
- Coloma Mi
Do you have traction control?
Is there a brand of gears you prefer? Need the intall kit?http://www.fquick.com/csmith4153
2011 Camaro SS
1986 Monte Carlo SS
while were on the subject. 87 Trans am, 10 bolt, updated series 3 carrier, richmond 3.73 gear. (drum brakes & posi)
My buddy noticed my drivers side rear tire wobble a little bit.
So i took it into Discount tire, had them check for a bent rim. (I already had to replace one rim)
They said the rim and tire are fine.
I jacked the car up (with the tire still on) and noticed a very small wobble.
Next thought is my axel. For the love of GOD......I'm not sure how a 305 could bend an axel. I really dont beat on my car a lot. So buy a new axel? Buy 2 new axels? A buddy told me to buy moser axels it I plan on keeping the car.
Heres a twist though, I have a parts car 85 trans am (disc breakes) rear end (not posi) 10 bolt.
1st do I have to swap rear ends to take the disc brake set up, or will it bolt on if I take all my drum parts off? I know I will still need to swap axels then also.
If I have to swap whole rear ends, then I have to swap my new gears in.
I dont want to lose my 3.73 gear.
Or lastly......just say leave it as it is, because its really not that bad to begin with?sigpic
Todd the housings are the same.Originally posted by tenpin842 View Postwhile were on the subject. 87 Trans am, 10 bolt, updated series 3 carrier, richmond 3.73 gear. (drum brakes & posi)
the problem comes down to swapping. I know there all the same. (10 bolt - 7.5, hell even the axels are the same length 30 5/16" (but different disc or drum))
Do I swap my gears into the 85 diff
Do I swap the axels and the disc brake set up onto my 87 diff
(hoping that the axels in the 85 rear end are good)
Do I buy 1 new axel or 2 new axels....if I go that route.sigpic
no traction control and whatever brand is recommended on the gears. install kit??? whats this consist of???Originally posted by csmith4153 View PostDo you have traction control?
Is there a brand of gears you prefer? Need the intall kit?sigpic
1998 Formula
I'd Swap it all into the housing in the car. No need to remove the carrier then.Originally posted by tenpin842 View Postthe problem comes down to swapping. I know there all the same. (10 bolt - 7.5, hell even the axels are the same length 30 5/16" (but different disc or drum))
Do I buy 1 new axel or 2 new axels....if I go that route.Western Michigan Camaro Club ~ President
- 2164
- Creight Smith
- Coloma Mi
I'll look some stuff up and get back to you.Originally posted by turbocreeper View Postno traction control and whatever brand is recommended on the gears. install kit??? whats this consist of???http://www.fquick.com/csmith4153
2011 Camaro SS
1986 Monte Carlo SS
