where to find axles
  • where to find axles
    since i believe my axle is bad, whereabouts do i find replacements. the axle must be bad because after changing out bearings, the noise is still there and sometimes even seems louder.
    what bearings did you replace? the wheel bearings? or the pinion, or?
    is it gear whine? if so, that could be preload/lash issues with the diff.
    if you are buyin a new diff, you want to stay stock or go to a 12bolt?
      Ive got the number to the guy who just rebuilt my rear end, Im sure he can get what you need.
      His name is Scott and the Name of his company is driveline solutions
      586-218-7140
      He's also a sponsor on LS1tech.com
        i only changed out the outside axle bearings, but forgot to pay attention to the axle. it sounds like its only coming from the passenger rear. i havent messed with the diff yet but would like to add some 3.73s.
          How about a site sponsor?
          2011 Camaro SS
          1999 Camaro SS #4153
          1986 Monte Carlo SS
          1969 Camaro - 427 Rat
            how about a price for an axle and some 3.73 gears?
              Do you have traction control?
              Is there a brand of gears you prefer? Need the intall kit?
              2011 Camaro SS
              1986 Monte Carlo SS
                while were on the subject. 87 Trans am, 10 bolt, updated series 3 carrier, richmond 3.73 gear. (drum brakes & posi)
                My buddy noticed my drivers side rear tire wobble a little bit.
                So i took it into Discount tire, had them check for a bent rim. (I already had to replace one rim)
                They said the rim and tire are fine.
                I jacked the car up (with the tire still on) and noticed a very small wobble.
                Next thought is my axel. For the love of GOD......I'm not sure how a 305 could bend an axel. I really dont beat on my car a lot. So buy a new axel? Buy 2 new axels? A buddy told me to buy moser axels it I plan on keeping the car.
                Heres a twist though, I have a parts car 85 trans am (disc breakes) rear end (not posi) 10 bolt.
                1st do I have to swap rear ends to take the disc brake set up, or will it bolt on if I take all my drum parts off? I know I will still need to swap axels then also.
                If I have to swap whole rear ends, then I have to swap my new gears in.
                I dont want to lose my 3.73 gear.
                Or lastly......just say leave it as it is, because its really not that bad to begin with?
                  Todd the housings are the same.
                  — Thomas Jefferson
                    the problem comes down to swapping. I know there all the same. (10 bolt - 7.5, hell even the axels are the same length 30 5/16" (but different disc or drum))
                    Do I swap my gears into the 85 diff
                    Do I swap the axels and the disc brake set up onto my 87 diff
                    (hoping that the axels in the 85 rear end are good)
                    Do I buy 1 new axel or 2 new axels....if I go that route.
                      no traction control and whatever brand is recommended on the gears. install kit??? whats this consist of???
                        I'd Swap it all into the housing in the car. No need to remove the carrier then.
                        — Thomas Jefferson
                          I'll look some stuff up and get back to you.
                          2011 Camaro SS
                          1986 Monte Carlo SS
