running a power wire
    Yeah the seperate sides thing is just an old myth. As long as you have half decent wiring, you should be alright, and yes, standard copper wire from radioshack will do just fine.
    Check out my FQuick!
      I have wires and nitrous through the pcm grommet and on drivers side I have stuff through the hood release cable grommet
        Originally posted by archemedes
        There is a current major competitor who has proven the wires needing to run on seperate sides is a myth (he finished first this year and has them bundled together) if you run a good twisted pair it is no problem (keep in mind your car body is a large wire since it's the system ground)
        For a sub amp I'll run RCA's down the same side as the power wire. With my 4-channel I ran both down separate sides since I ran speaker wire to the speakers separately anyway (was a Bose system). That PCM grommet is perfect though.
          Holy moly, Scott -- You've been on the site since day 4 and you only have 12 posts?
            makes no difference (the sub amp will actually suffer more from noise as it's adding frequencies it's not supposed to get)
