Need Suggestions on Speakers
    ummm yea... you haven't sat in my truck before then. I have their component set, from 6 yrs ago
    http://audiobahn.com/Audiobahn/
      subs are great, I used to have a set of 10 inch imortals which you would know are more like 12's and a jackhammer. I had a variety of subs from audiobahn, just not a fan at all of their components and yes I have had those as well.
        Pioneer, JL, Boston, Infinity, JBL, MB Quart, I've also heard good things about Memphis Audio.
          With the monsoon you have 4 wires going to each front door speaker and only certain speakers will work. The infinity 62.7's were the top choice but they are no longer available and the 62.9 is not a direct replacement. It has to do with the monsoon amp powering 1 part and the radio powering the other with 2 and 4 ohm I believe. Check out keeaudio as mentioned or try new/improved OEM replacements that are different now.
