Project CarPC v3
    I'll buy your 7" screen if you decide to upgrade to the 8". . . . Looking for a reliable touchscreen that I won't feel bad taking apart. . . lol
    Nick H.
    Current MIFC Vice President
      It's reliable but as you can see, the case is really bad, Nick.
        As for connecting the screen to the motherboard you can buy or nmake extensions very easily.
        1989 Chevrolet Camaro- Currently in pieces...
          You can, but I've read VGA cords being over 10 feet leads to degradation. Actually one of the cool technologies that I like is the VGA to cat5 adapters. Then you can have a lot more cat5 between the adapters to really extend the VGA connection.
            I'll be making a custom case for whatever monitor I get anyway. . . All I really need is the screen and what's left of the bezel you made. This one I won't feel bad about taking out of the case to do it. It will help to motivate me. . . lol
            PM me with a price and I'll see what I can come up with.
            Nick H.
              FWIW, I just installed a 50ft vga in or confrence room at work, seems fine to me. BUT I have seen that happen with cheaper cables.
                Really? Damn that's 5x longer than I thought it could be extended.
                  I bought it from firefold.com they have EVERYTHING, and so cheap its unbelievable. I was very worried the first time I ordered about my stuff not coming, but it came quickly and I have since ordered several times.
                  Heres there VGA section http://firefold.com/Categories/Video...GA-Cables.aspx
                  They carry up to a 150 footer.
                    I have used a 150foot VGA cable with no problem before either, used it at the skill center i went to.
                    http://www.tcevolution.com
                      150' VGA cable would be great if you needed to wrap the cable around the car 100 times before attaching it to the monitor. . . lol
                      Nick H.
                        lol well in that case you can mount your pc anywhere and just run the vga cable to it.
                          that depends on the quality of cable brian. Since i work with this stuff everyday at work, ive observed there are some differences in the cables. some of them are only 14 pin cables, where pin 13 (horizontal sync) is removed. We've had a lot of problems running the 50 foot 14-pin cables to our overhead projectors because it causes some pretty substantial shadowing. But when we replace them with 15 pin versions it pretty much eliminates the problem altogether. And then beyond just the different number of pins, you can literally eyeball the quality of the cable... if it looks cheap, it probably is. I never realized what kind of difference a VGA cable could make until i started comparing them on a nice new projector.
                            well whatever, it doesn't matter to me either way... I only need a 3 foot cable.
                              X2 Joel, quality is EVERYTHING, this 50 footer we have is FAT and 15 pins, and at 50 ft the image it produces is 100x better than a cheapie 6ft extension we bought for when we were in a pinch.
                                3 ft cable or 300 ft, a 15 pin is worth having over a 14 pin... if you are concerned about image quality.
