Can anyone please tell me how to tell if the "FACTORY" SS hood I just purchased is actually a factory hood? I have looked everywhere and can't find any markings on it.
Question about 97 SS Hood
Post pictures of top, bottom, and front edge... and I can just tell you
- Greenville, MI
- Die Maker
Should have MADE IN CANADA in two locations on the underside.
If you got it cheap then I'd expect it to be aftermarket. Original SLP hoods are worth a big chunk of change
Originally posted by JoeliusZ28 View PostPost pictures of top, bottom, and front edge... and I can just tell you
Originally posted by hoogiesngrinderz View PostShould have MADE IN CANADA in two locations on the underside.
Ok Joelius, I will do. I can tell you that it has a closed scoop vent meaning it just has a solid grill and not open on the bottom. I have looked all over it and seen nothing stamped that I can see. I only gave $375 for it so it's no biggie....fits perfect, in perfect condition and feels solid.Thanks,
Stephen
Yeh, ah, that's what I was thinking also but for $375 and it fits like a glove it's worth it to me. Besides, it will be functional when I'm finished with it lol....Thanks mazakman.....!Originally posted by mazakman View PostI have a 97ss camaro my hood is open and functional. Seems like to me a factory ss hood would only come this way.Thanks,
Stephen
Wrong, the aftermarket hoods are functional as well.Originally posted by mazakman View PostI have a 97ss camaro my hood is open and functional. Seems like to me a factory ss hood would only come this way.2002 Z28 Camaro A4
I think he meant that a factory ss hood would only be configured that way, not the only one that is... Meaning the op's hood is aftermarket
Still waiting on pictures either way though
OK, Here are the pics you requested Joelius....Let me know what you think.image.jpgimage_1.jpgimage_2.jpgimage.jpgimage_1.jpgimage_2.jpgOriginally posted by JoeliusZ28 View PostPost pictures of top, bottom, and front edge... and I can just tell you
Thanks,
Stephen
Sorry for the pic doubles....Thanks,
Stephen
i'd have to see it in person to say for sure, but i think that is an OEM hood. All the dimensions appear to be correct. I can say with 100% confidence it isnt a glasstek or RK Sport which are the two most common knockoffs (ive got a glasstek on mine).
Another clue would be if you were able to use the same bolts for the hinges and the lift shocks. (i couldnt)Last edited by JoeliusZ28; October 26th, 2013, 04:29 PM.-Joel
Joelius, i used everything from my old hood...bolted right up including hood shocks....Originally posted by JoeliusZ28 View Posti'd have to see it in person to say for sure, but i think that is an OEM hood. All the dimensions appear to be correct. I can say with 100% confidence it isnt a glasstek or RK Sport which are the two most common knockoffs (ive got a glasstek on mine).
Another clue would be if you were able to use the same bolts for the hinges and the lift shocks. (i couldnt)Thanks,
Stephen
That piece is interchangeable, but i cant say ive seen a 100% closed one before.Originally posted by FASHOOTER View PostPretty sure it wouldn't be closed behind grill if it was an OEM
I'd put my money on this being an OEM hood based on the info we have so far.-Joel
Thanks Joelius, the fellow i bought it from said it was from an OEM SS car????Originally posted by JoeliusZ28 View PostThat piece is interchangeable, but i cant say ive seen a 100% closed one before.
I'd put my money on this being an OEM hood based on the info we have so far.Thanks,
Stephen
