Question about 97 SS Hood
  • Question about 97 SS Hood
    Can anyone please tell me how to tell if the "FACTORY" SS hood I just purchased is actually a factory hood? I have looked everywhere and can't find any markings on it.
    Thanks,
    Stephen
    1997 Z28 LT1 - A4 30th Anniversary
    Post pictures of top, bottom, and front edge... and I can just tell you
      Should have MADE IN CANADA in two locations on the underside.
      If you got it cheap then I'd expect it to be aftermarket. Original SLP hoods are worth a big chunk of change
        Ok Joelius, I will do. I can tell you that it has a closed scoop vent meaning it just has a solid grill and not open on the bottom. I have looked all over it and seen nothing stamped that I can see. I only gave $375 for it so it's no biggie....fits perfect, in perfect condition and feels solid.
        Thanks,
        Stephen
          I have a 97ss camaro my hood is open and functional. Seems like to me a factory ss hood would only come this way.
            Yeh, ah, that's what I was thinking also but for $375 and it fits like a glove it's worth it to me. Besides, it will be functional when I'm finished with it lol....Thanks mazakman.....!
            Thanks,
            Stephen
              Wrong, the aftermarket hoods are functional as well.
              2002 Z28 Camaro A4
              1993 Z28 Camaro M6- SOLD
              1999 Z28 Camaro M6- SOLD
              2008 Ford Fusion SE - DD
                I think he meant that a factory ss hood would only be configured that way, not the only one that is... Meaning the op's hood is aftermarket
                Still waiting on pictures either way though
                  OK, Here are the pics you requested Joelius....Let me know what you think.image.jpgimage_1.jpgimage_2.jpgimage.jpgimage_1.jpgimage_2.jpg
                  Thanks,
                  Stephen
                    Sorry for the pic doubles....
                    Thanks,
                    Stephen
                      i'd have to see it in person to say for sure, but i think that is an OEM hood. All the dimensions appear to be correct. I can say with 100% confidence it isnt a glasstek or RK Sport which are the two most common knockoffs (ive got a glasstek on mine).
                      Another clue would be if you were able to use the same bolts for the hinges and the lift shocks. (i couldnt)
                        Joelius, i used everything from my old hood...bolted right up including hood shocks....
                        Thanks,
                        Stephen
                          Pretty sure it wouldn't be closed behind grill if it was an OEM
                            That piece is interchangeable, but i cant say ive seen a 100% closed one before.
                            I'd put my money on this being an OEM hood based on the info we have so far.
                              Thanks Joelius, the fellow i bought it from said it was from an OEM SS car????
                              Thanks,
                              Stephen
