i just got me the dual gauge pod, its black and my inter is dark grey, maybe not noticeable maybe it would be, a friend said not to worry but figured i put this up, should i dye the post and pod together to mach or not worry incase in messes it all up so nothing matches, not sure what grey i have i just know its dark.??? thanks.
to dye (paint) or not to?????
I'd just get it close. I have a can at the shop that matches the grey interiorDoing less with more
I don't think you can dye a lighter color very easy. I know you can dye a darker color without any issues.
I have used the plastic paint from Duplicolor without any problems and it seems to hold up well.
Make sure you clean it good before painting it.
well i got the grey like rubber bumpr paint as close as i could get, wet was a little shiney but still dark grey, maybe after it has dried in the plastic a little bit might look like it belongs, if not still grey instead of black,sigpic
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
