So I have the disc brakes off my spare rear axle and I cleaned them up a lot with some engine degreaser, a wire brush, and dish soap. However there is some grime built up that either I cannot reach with my brush or it is not budging. Is there anything besides brake parts cleaner that would do the job.
For those of you following my powder coat project, I will keep you posted in the next week or so with pics.
Will do. I have some Red powder coat I was going to use but then I found a deal on some gloss black and some clear powder. I have pics of my cleaned brake parts ready for powder. I will post pics up later.
Sand or Media Blasting is the best and quickest way to accomplish what you're after. Also, if there is ANY SMALL residue of grease/cleaners, etc., ANY form of paint will lift-PERIOD!
sigpicWe live in the Land of the Free and Home of the Brave. If you're not willing to defend her, you're not worthy to live here, so get out.
Most coaters blast the part first. If not then what is that acid for stains on bricks? Starts with a "M". Miric acid or something like that. That should do it.
94 Z28 Vert. A4->M6, Pro 5.0 Shifter/Short stick, Mccleod 7500rpm disc w/ Ram Alum flywheel, 3.42 gears, CAI, XE 224/230 .553/.561 lift w/ 1.65 RR's, LE Stage 3 Heads, 30lb SVO injectors, JetHot LTs, X-pipe Duals, LT4 Knock Module, Personal Tunercat PCM Tune. College, Grad school, and Med School Loans: payment countdown only $272,000left. 8-OInstall pictures
