Originally posted by 93formulalt1
View Post
Tail Light Panel "shaved with back light"
yea the guy's firehawk is for sale right now, he has TONS of led work on it, he even bought a clear license plate cover for the front and then painted all but the bird and then put a decal on it with a little bit of clear still there, at night the bird on the front of the car would also light up white, during the day it looked like a normal front with an overlay. The back panel is even easier for birds because you can simply remove that black piece, if I recall he even had a step by step howto of how he did it, you may be able to use his wiring techniques and such on your setup.-Derek-
Yeah, he used part of the stock part, but the exposed part was formed out of plexiglass, painted, and epoxied over what was left of the stock part. Very simple plan, but the execution would be rather easy to mess up. . . lol He has one SWEET car, the LED work he's done to it really make it unique.Originally posted by redfbird99 View Postyea the guy's firehawk is for sale right now, he has TONS of led work on it, he even bought a clear license plate cover for the front and then painted all but the bird and then put a decal on it with a little bit of clear still there, at night the bird on the front of the car would also light up white, during the day it looked like a normal front with an overlay. The back panel is even easier for birds because you can simply remove that black piece, if I recall he even had a step by step howto of how he did it, you may be able to use his wiring techniques and such on your setup.Nick H.
Current MIFC Vice President
This is the link to the mod i mentioned above:
http://www.ls1tech.com/forums/showthread.php?t=391715sigpic
1999 Firebird V6 3800
Y87 Performance Package
W68 Appearence Package
SLP Cold Air Induction
InActive Member
- May 26th, 2008
- 74
- Frank S
- 1998 Chevy Camaro v6
- Warren, Michigan
- IT Tech & Web Photographer
Originally posted by 99BadBird View PostThis is the link to the mod i mentioned above:
Thanks for the link.... wow that guy did a lot of LED's..... I hope to have the new panel here this week then I will start to work out how I am going to do this...
Fenix Bloodstonesigpic
InActive Member
- May 26th, 2008
- 74
- Frank S
- Warren, Michigan
Okay I have the donor part cost $10.00 for it on Ebay and $30.00 in shipping charges which I think is a bit much, since it only came from Witt, Illinois and I am in Detroit Area. But it is only $40.00 for this part so far, I will be keeping detailed info of my work and of course as it comes along I will post photos. I have not decided on lighting yet, But I think I am going to have it lit I think I am going to do hook it up to the running lights, I will see.
Thanks for all the input everyone.
someone on ls1tech already did this i saw a thread a couple months ago. looked sick. ill see if i can find it
edit: found it
http://ls1tech.com/forums/showthread...id+what+i+look
http://www.youtube.com/watch?v=bHRaafx6TuI
InActive Member
- May 26th, 2008
- 74
- Frank S
- Warren, Michigan
Originally posted by italicizedsponge View Postsomeone on ls1tech already did this i saw a thread a couple months ago. looked sick. ill see if i can find it
edit: found it
Yeah that is cool, But I am looking for something that don't show the camaro unless it is lit up.
That's awesome!- Brian Meissen
Obsessed
- October 31st, 2006
- 986
- Dale
- 2002 Camaro v6
- Millington, MI
- retail, and body work on the side
just get a thin piece of plexy 1/8" thick, since that part of the pannel is fairly square i'm sure you could cut out a square of fiberglass and glass in the plexy. Then once you have it all glassed in, buy some vinyl camaro decals and place them on the outside in the correct position before you paint. Then once you lay down your basecoat then peel up the letters thus giving you clear letters on the pannel. Then Lay down a good clear coat over the front and should look pretty sweet. The only thing is that i don't know if you need to rough up the back of the plexy behind the letters in order for it to grab any light. It seems as though i've seen people use plexy and if it's not roughed up on the back it does not show the colored light as well. I don't know well sounds like a great project good luck.sigpic
"Blue Devil"
