I'm gonna have to do some looking around and find a suitable spot...Thanks for the ideas..
Where to mount a Fire extinguisher
Find some sort of mount and mount it right to the back of the driver's seat. That way in case of fire, it's right behind you. Or like Mark said, behind the Passenger's seat.- Brian Meissen
Mine is tucked on the outboard side of the drivers side rear seat. I need to actually mount it there though. I put one in the car after my buddies mustang engine bay caught fire and he couldn't put it out right away. Basically toasted the whole front of the car. I need to mount it though cause I had to hit the brakes hard once and the old extinguisher slid forward, hit my seat bracket, that sheared off the safety pin, and the pressure from the seat bracket activated the trigger and started spraying my rear carpet. DOH! Replaced that extinguisher and this one stays put better but should still be locked down. It is an easily accessed point for the driver. I can either reach behind me to grab it or open my door and it is right there.My Toys: Hugger Orange 1999 Z28 6-Spd Twin Turbo
1937 Chevy Extended Cab Pick-up (One of a kind)
Future Toy: Orange Ultima GTR or SLC
Haha, that wasn't in downtown Mt Clemens, was it Tony? I used to have an extinguisher that I'd carry in my car but a mustang caught on fire there and I grabbed my extinguisher and wasted it on his car.
In the '73 it is mounted in the trunk along with a first aid kit and tool box. All of which are bolted or velcro in place. At most points judged shows you get an extra point for each and many times that makes the differance. Can't tell you how many people I've loaned my extingusher and first aid kit to before judging (as long as they weren't in my class LOL).
HOWEVER, I keep a small Halon extinguisher in the glove box.
In the '01 it is mounted in the open well in the rear drivers side along with a first aid kit. The chances are much greater of you needing it to assist someone else than to put out your own fire.
I say put it where it looks the best and keep a small Halon up front if you are worried.'73 Z28 388 Stroker, M22 Rockcrusher 4 speed
WMCC Photographer and owner of Redline Photography
You are only young once but you can be immature your whole life!!!
No, this happened down the street from his own house. I think in Pontiac. He used a neithbors hose to put it out, but by the time he got it over there the engine bay was torched. His 2nd rebuild is almost finally done again. A lot of folks on Motown came together to help him out again.Originally posted by meissen View PostHaha, that wasn't in downtown Mt Clemens, was it Tony? I used to have an extinguisher that I'd carry in my car but a mustang caught on fire there and I grabbed my extinguisher and wasted it on his car.
No N2O is not flammable. But if there is enough pressure on the tanks I would be concerned about the tanks bursting under high heat. I mean think about it. How much can you heat a volume of any gas container before the pressue becomes so much that it would blow. I would think however the force of the blast would extinguish the flames would it not?Originally posted by 93formulalt1 View PostGuess I've seen "The Fast and the Furious" a few too many times. . . lol That scene where the nitrous tanks explode was pretty cool. Why can't all ricers meet their end like that? I didn't know nitrous wasn't flammable. I guess you do learn something new everyday.
Which is why the bottles have a blow off valve(allowing the bottle to relieve the excess pressure before exploding) and if you're smart you have a blow down tube which lets the nitrous exit outside of the car in the event of too much bottle pressure.. See pic below with crappy arrow pointing to tube....Originally posted by phoenix_rising View PostNo N2O is not flammable. But if there is enough pressure on the tanks I would be concerned about the tanks bursting under high heat. I mean think about it. How much can you heat a volume of any gas container before the pressue becomes so much that it would blow. I would think however the force of the blast would extinguish the flames would it not?
