Underhood help
  • Underhood help
    Once the 60 degree days start hittin' I will be resuming my project, first thing on my agenda is to fix the rust in my engine bay, one problem, I have to strip all this black gunk, it is over like a tanish substance that is a bizotch to scrape off. Is there any method for stripping this crap off?
    It's easier to make a 3rd gen faster than to make a 4th gen look good
    heat gun and a scraper
      Engine cleaner and elbow grease.
      It's not a pleasant job.
      WD-40 for the hard to reach places, with a tooth brush.
        engine degreaser, let it soak a bit and power wash
        scrape off the rest
        '96 Camaro RS - project
        '97 Silverado Z71 - DD
        '89 Suzuki GSXF 750
          scrape off the rest
          I stay away from power washing the underhood...too many important electronic things under there...
            Yea I always power spray my cars when i get them, cleans all the gunk off everything etc
            but yea, cover up the air intake/coils and as long as you dont sit there and spray all the electronic stuff it should be fine...
            '89 Suzuki GSXF 750
              WD-40 was designed as a water displacing liquid. so if you power wash it. spray the electrical connections with WD-40 after and that will displace all the water and there you go, a working engine again. haha
                Be careful with WD-40. WD40 over time absorbs water and the water doesn't go anywhere. I suggest using a silicone spray. It will resist the water and keep the rubber components sealed.
                  Yep.
                  Water Displacement on the 40th Try!
                    k, thanks guys!
                      Heat is your friend...that and lots of laquer thinner!
