Does anybody else have issues with condensation in a reverse light?? How do you get rid of it?? I was once told to drill small holes somewhere in the housing. Is there a better solution?
Condensation in reverse light
We do its a 99 camaro, but were gonna replace them, where they came togather the lense and housing, was leaking, so were gonna replace them, we have tryed sealling it, Just comes back, Also It didnt help that the previous owner put the wrong balbs in the rear to make the lense suck in a little eather... He installed the ones that were a little to hot..... LOL LOLL...
Could be the bulb seal, could be the seal between the outer lens and the housing.Originally posted by TheMyth View PostDoes anybody else have issues with condensation in a reverse light?? How do you get rid of it?? I was once told to drill small holes somewhere in the housing. Is there a better solution?
Don't drill unless you have no other option...that's only a band aid...it will come back...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
dittoOriginally posted by 19Xtreme99 View Postits a bad seal. you'll have to take it apart and let it dry out. then check the seals where the bulb goes into the housing.
InActive Member
- November 18th, 2007
- 439
- Mike
- 2002 Camaro LS1 M6
- Ortonville Michigan
- Fork lift repainter
Take the bulb out on warm sunny day and it should dry right up and then check the seals, my right clear corner condences all the time so I ussually pop the bulb out and it dries right up.
if we bother to try and fix'em - then the assembly gets pulled and blownout with an air hose then we run a bead of silicone around the edgesLast edited by TSTONE; February 20th, 2008, 05:08 PM.
