Converting 93-96 Gauge Cluster Bulbs to LED
  • Converting 93-96 Gauge Cluster Bulbs to LED
    I didn't know exactly how to title this because there's more to it than a fancy name. Basically, this is a writeup if you have a 93-96 Camaro and you want to convert the "main bulbs" to LED (IE: The tach, speedo, and gauges, not the secondary "light up icons") Likewise, this may not work with stock gauges, as the stock gauges have a blue plastic backing on them which means red LEDs won't shine through.
    Materials Needed:
    194 wedge-style Inverted-Cone Wide Angle LEDs [I purchased from Superbrightleds.com]
    Taking the gauges out is the most time consuming part of it. You'll have to remove the radio bezel, the knee bolster, the A-pillar, and the dash pad all just to gain access to the bolts to remove the gauge cluster bezel. The bolts are all 10mm as I recall. Once the cluster bezel is removed, there's 4 bolts that hold the cluster in place. Unplug the cluster, and take the gauges to your workbench or kitchen counter. You'll need a small torx tip to remove all the little screws from the black plastic cover that protects the circuit board on the back of the gauge cluster. Once that's removed, the real conversion begins.
    Once you have the black plastic cover off, you have perfect access to all the bulbs. These bulbs are meant to be replaced socket and all. Well, you only ordered 194 base LEDs [that's all you need], so here's the trick. Slip on a pair of rubber dish gloves, they'll not only give you extra grip, but protect you from bits of glass. With the gloves on, grib the base of the glass bulb and the plastic socket, and pull them apart. It doesn't take too much to break the bulb loose. Once you have removed the bulb, you now have a perfect socket for a 194 wedge bulb. Take your LED and bend the leads on them so they point down, instead of being against the base as they come. With the leads pointed down, insert the 194 wedge LED into the socket. Bend the leads to make contact with the metal strips on the sides of the socket. You'll need a soldering iron and solder to ensure a strong, secure connection between the lead and the metal. I tried just bending it, but that wasn't enough when I tested it.
    Once your bulbs are soldered into place, simply plug them back in and go out to your car and test. Make sure you test first, before putting the black cover back on. The bulbs are polarized, so if a bulb doesn't turn on when you test the lights, twist the socket back out from the gauges and turn the socket 180 degrees and then try it again and it should light up. If not, check your solder joints. If everything lights up ok, then you've just gotten a great new LED-lit gauge cluster! Put it all back together and enjoy the new lights.
    Bulbs to replace with the 194 wedge LEDs:
    The results:
    that really is cool all lit up, but can you see your speed at night like that? maybe it's just the glare.......
      I've been having a horrible time capturing what it looks like in person. My camera absorbs too much light, so it comes out looking hella bright like that. Here's some images from my dad's camera which makes it look dimmer than they really are, but the last picture I edited with Firefox to try and make it look like it does in person.
      And the edited one. I brightened it and did more contrast. The color is about right, but it's a tad brighter than these pics. Also, you can clearly see the difference between the red LEDs and the regular bulbs (the seatbelt icon)
        um, your speedo is on fire, might want to put that out. cool transformation
        5th gen Camaro V6 Forums
        http://www.bowtiev6.com
          Here's a cool "before and after" (I forgot I had this pic)
            That looks pretty bright!!!
            i want to make all my gauges glow red...but i still want the factory gauge overlay. maybe i'll just have to get like a "platinum" or "white" faced gauge overlay to put red lights behind it?
            1998 Camaro SS Bullseye Turbo
              I'm thinking of buying one of those stainless steel guage overlays and painting it Orange to match the car color exactly, but I'm not sure. Great job, B!
              Nick H.
              Current MIFC Vice President
                Is there any way to get at the back of the guage face? I would just remove the tape and install Orange LED's, but I want it to look kinda stock lol. Any suggestions?
                Nick H.
                  nada. it's glued on, so if you remove it you'd have to like glue it back on.
                    How about a reverse glow gauge kit? They sell cheap on ebay all the time, are they as bright? I really want my dash to pop out. I think I'll just get that and a lighted gauge needle kit from EBay. Really cheap, and i think it would look pretty cool. And a stainless steel surround painted Orange as I mentioned above would look awesome with that.
                    Nick H.
                      Bringing this back from the dead because this is such a sweet write up! I'm going to the junkyard to rip out a AC control cluster to see if it's possible to change those ones too!
                        That would be sweet...but time consuming, ill leave this as a wishful mod
                          I got some white overlays that still glow stock red... Ill be putting in led's here in about a month heres a crappy cell phone pic and yes I a bulb is burned out, I found that out after i was finished and with it being so cold i dont feel like fixing it just yet
                          99 Grand Prix GT - Winter Ride
                          ___M&R Electronics ___
                          .MECP & ASE Certified.
                            I also have the HVAC and Headlight overlay, just no pics yet
                              yea id do it if it was as easy as my truck... which is plug and play.
