Huron Speed A/C Retaining T4 Kit
-ONE complete package deal In-Stock and shipping daily, no wait time! Don't Miss out!
This package special is in stock, and is available to ONLY the first person to purchase for a $800 savings!!!! MI-Fbody Member Special Price ONLY!
***Kit has many of the same features as the already successful kit Truck Manifold kit, however obviously retaining A/C with the use of a C6 manifold and a truck manifold combination fitting through a Turbo K-member. Kit will require the use of a Turbo K-member (was built around a PA Racing Super Turbo K-member) This can be purchased with your kit for a great price, or separately.
Includes:
-2-piece hotside in 2.5” piping w/ T4 flange and 44mm Wastegate Flange
-2.5” V-band clamp for easy connection of 2 hotside pipes.
-3” 1-piece Downpipe
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-F-body front mount intercoolers brackets
-F-body alternator & tensioner relocation brackets
-Hardware to mount Turbo, intercooler brackets, intercooler, alternator & tensioner relocation to vehicle
-Turbonetics 7875 .96 a/r Ball Bearing Turbocharger
-XSPower 44mm Wastegate (Black, Silver, Red or Blue)
-XSPower 50mm BOV (Black, Silver, Red or Blue)
$3295 + FREE SHIPPING
Pricing good for MI-Fbody members ONLY!
-We can add in a PA Racing Super Turbo K-member to this package for you for $550
-We can upgrade the turbo to the Turbonetics BILLET 7575 Ball Bearing unit for $225
All piping made from 321 stainless steel, fully polished.
Advantage of using factory GM manifolds, no fear of aftermarket headers or manifolds cracking due to the turbo weight! :judge:
Advantage of having the Huron Speed customer service!
Requires Oil Lines, Pusher Fans, Misc Hardware, passenger side Truck Manifold to use on drivers side, and a passenger side C6 Manifold to run on the passenger side to complete
Kit requires a Turbo K-member (built around the PA Racing Super Turbo K-member) and lowering or removal of front sway bar
Huron Speed
Kit shown as you will receive it (You can select the color of your Wastegate and BOV)
Includes:
-MAF Delete pipe
Huron Speed
