Huron Speed Turbo Kit Package Deal - MIFbody Special
  • Huron Speed Turbo Kit Package Deal - MIFbody Special
    Complete Truck Manifold Turbo Kit in stock and ready to ship. Special Pricing ONLY VALID FOR MI-Fbody Members.
    Kit complete in 3 different forms!
    1.) Complete Kit plus T-series Ball Bearing, BILLET 7575 turbo, XSPower 44mm wastegate, 50mm BOV, and oil lines
    2.) Complete Kit plus T-series Ball Bearing, Cast 7875 turbo, XSPower 44mm wastegate, 50mm BOV, and oil lines
    3.) Complete Kit plus TC78 turbo, XSPower 38mm wastegate, 50mm BOV, and oil lines
    Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit SPECIAL PACKAGE DEAL!
    Special
    MI-FBODY ONLY only pricing:
    Package 1: $3495 SHIPPED
    Package 2: $3295 SHIPPED
    Package 3: $2850 SHIPPED
    -Pricing good to mifbody members Only!
    Extra Features:
    *Standard Huron Speed Truck Manifold Turbo Kit
    *Included Hardware for Alt Relocation, Intercooler Brackets, and Turbo mounting
    *Huron Speed T-Shirt
    *Huron Speed Windshield Banner
    *Huron Speed Small Sticker
    *Turbonetics Turbo (You choice to fit your needs/goals)
    *XSPower Wastegate
    *XSPower 50mm BOV
    *Oil Feed line with fittings
    *Oil Drain line with fittings and flange
    *If interested, please contact us via PM, or e-mail to: huronspeedproducts@gmail.com to purchase!*
    -This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, oil-lines, etc as you can see from the picture!
    -Hot & Cold Side piping is made from 321 Stainless, yes 321, and polished!
    Components:
    -Turbonetics Turbo. Carries a 1-year warranty from Turbonetics!
    -XSPower Wastegate
    -XSPower 50mm BOV
    -2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
    -3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
    -3" Cold side piping from turbo to FMIC to Throttle Body
    -50mm Blow-Off Valve Flange on Cold side piping
    -Oil feed line with fittings
    -Oil drain line with fittings and flange for off the turbo
    -4" core front mount Intercooler
    -All exact, specific couplers
    -All exact, specific T-Bolt clamps
    -F-body front mount intercoolers brackets
    -F-body alternator relocation brackets
    -Hardware to mount your Alternator Relocation kit, intercooler brackets, and turbocharger!
    -Huron Speed Boost Gauge T-Shirt (Small-3XL)
    -Huron Speed Windshield Banner
    -Huron Speed Small Sticker
    Piping made from 321 stainless steel, fully polished.
    Requires Pusher Fans, Misc Hardware, and Truck Manifolds to complete
    Kit requires removal of the A/C, Low Oil Sensor, and lowering or removal of front sway bar
    i had my wrx sold this weekend... then on my way over here to detroit the center differential started making noise... if the car ever sells i'll be ordering one of these up!
      Bump! Have added a few packages and extended this special to members!
      *If a mod could please, change the title to: Huron Speed Turbo Kit Package Deal - MIFbody Special
      Thanks!
        You are killing me Jonny!!!
        2000 Formula
        fixed slow junk
          You know you want / need boost!
            Thats a smokin deal!
              Damn my cammed car lol.
              just out of curiosity, how well would my existing setup in my sig work with this setup? -minus the fact that i would need some tranny work done lol
                I had a very similar setup as you and think the change was well worth it! After selling my Livernois heads, QTP longtubes, etc I didn't need to invest all that much more (pretty sure it would have cost me more to keep the old setup and do nitrous with all the controllers, solenoids, nano, etc).
                  I want boost - I'm trying to resist the urge......A/C kits just outside of my reach right now, and the wife wants to fence in the back yard.
                  2000 Formula
                  fixed slow junk
                    You know I will work with you on the A/C kit for a smoking price also
                      I know - just need to keep the wife happy.
                      2000 Formula
                      fixed slow junk
                        Is this deal still going on or do you have any deals going on soon? I will most likely be ready to order in the next month or two.
                        2005 Chevy 2500HD, Duramax, DD/tow vehicle, 20x12's, DSP5 w/Kory Willis tunes, head studs, EGR delete, LBZ MP, 4" MBRP
                        99 T/A, A4, Black, SLP Flo-pac, LMII, LS6 intake, PS LT's, TSP ORY, 42# injectors, stock 243's, comp cam 230/232 612/595, UMI rear suspension, Yank SS3600, Built trans, 3.42's, other small stuff.
                        11.72 at 116mph, 1.61 60ft, N/A
                        11.41 at 124mph, 1.72 60ft, a little giggle gas in 2nd/3rd and no traction
                        New setup in the works!!!
                          Hell yes! Happy to see this Josh! And very jealous!!
                          2002 Z28 Camaro A4
                          1993 Z28 Camaro M6- SOLD
                          1999 Z28 Camaro M6- SOLD
                          2008 Ford Fusion SE - DD
                            Yes, Shoot me a PM with what you are looking for! Thanks
                              Yeah Mike it should be a blast!!! I will PM you tomorrow Jonny.
