Hke 408 $3850
  • Hke 408 $3850
    I have an HKE Precision racing engine 408 short block available.
    Eagle crank
    Scat I beam rods
    Wiseco pistons
    GFX rings
    ARP mainstuds
    ACL race coated bearings
    -8cc pistons 11.07:1 compression (typical 66cc head)
    $3850 plus crate and freight
    We typically can not keep an HKE engine in stock, the demand for them is far to great but I we have one shortblock right now in stock.
    All engines:
    Hone block with appropriate Torque Plates
    Line Hone Main Bores with ARP or OEM Fasteners
    Set Deck W/ Customer's Pistons and Surface to Correct
    for Required Quench
    Balance Rotating Assembly
    We can turn this into a long block for you as well.
    MSD 8.5mm Superconductor wires w/ NGK $68 delivered, custom length LS1 LT1.
    HKE Precision Racing Engines 347-506 cid N/A, N2O, FI applications
    AFR, TFS, All Pro, Edelbrock, Dart head cam specials
    Ron Davis Racing.. radiators and heat extractors finest in the business
    Do want... I'll get back to you after I do my taxes and someone buys my wheels
    TEA Stage 2.5 5.3 Heads/TSP 228r Cam/LS6 Intake/MWC 9" 3.90s/Custom Nitrous Kit
    574 RWHP/612 RWTQ
    **************.com
      URGH! I Want. ill hand over everything i own lol. good luck with the sale man.
      94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60' Sold/Stripped
      94 Z28 383 LT1 A4 SNAPPED CRANK
      1992 Camaro RS 305 700r4 Convert.
      1986 Dodge Ramcharger 318 Dually Rear, Camo paint. Scrapped
      1993 s10 4x4 5spd 4.3 on 31s awaiting a lift. [COLOR=rgb(0,0,0)]traded for...[/COLOR]
      1998 Jeep Grand Cherokee 4.0 I6 getting 3in lift and 31s within a week or two
      "Life is full of decisions, You make them and don't look back"
        thats not a bad deal at all!!! what kinda power are those i beams rated to
        do you guys offer anything bigger then a 408 in an aluminum block?
        The LS1 or Go Home Crew
        ASE master certified
          aluminum block all depends on your budget as to how big it is. The rod on this 408 can be ugraded if a person wants but the I beam is strong enough at the rpms this engine will see. We can upgrade to an Eagle H beam for $100 more and a Compstar for $275 more if a person wanted to but HKE will tell you flat out the Scat I beam is fine.
            Little more info on the Scat I beam.. its good for anything n/a under 7500 rpms and light n2o or FI use.. 700 rwhp is not an issue.
