LS1 steam pipe, starter, and clutch cables
  • LS1 steam pipe, starter, and clutch cables
    as the title states, i'm looking to buy a LS1 steam pipe, starter, and clutch cables from a LS/f-body.
    morning bump
      got the steam pipes, still looking for a cheap starter and the clutch cable.
        Clutch cables?
          Clutch Master Cylinder maybe?
          Makin Torque.
            clutch line, my bad. hydraulic line that goes from the master cylinder to the slave cylinder. i'm probably going to just get this (http://www.summitracing.com/parts/mcl-139212) because it's cheaper than buying a all new master cylinder to get the line.
              got my new steam tubes today, and ordered that mcleod line.
              still looking for a cheap used starter.
                I've got a starter that has a small chip on one of the teeth. I filed it smooth and it was showing no wear on my flywheel when I pulled the trans
                2015 Silverado
                  Don't truck starters work?
                  Makin Torque.
                    I have a truck starter on my 98.
                    I've purchased 3 truck starters on ebay so far. I look for the two long bolt version (about $35) and get two new bolts ($15)
                      found one at a local junk yard for $60 from a '03 6.0
