WTB: SBC gen I long block
  • WTB: SBC gen I long block
    Hey All,
    I'm looking for a cheap gen 1 SBC 350/305 that runs (and that I can just drop into a project right away with minimal work). would like to get a long block. don't NEED an intake, but if it comes with a cheapo carb'd intake I would probably pick that up to. I would go craigslist.. but I figured I would come here first with people I trust.. VS going to craigslist and it be up in the air what I might get haha!
    thanks!
    -Jeremy
    "Project Shadowfax" <- Clicky Clicky
    1984 Pontiac Trans Am (15th Anniversary Edition)
    L69 (High Output 5.0) / 700r4 Auto Trans
    I got a 305 shortblock. Just needs heads. I have a pair that for the right price I'll let go, but I was planning on using them. I've never run it, but from what I understand from the po its a good engine.
    91 Firebird 305 TBI
      What were you looking to get for the shortblock? and then for the whole setup?
        I'll take $350 for it. Just realized that I don't have gaskets, head bolts, lifters, rods or rockers either. So .. Kinda up to you. Not exactly a drop in engine like you wanted lol.
        91 Firebird 305 TBI
          haha yea more than I wanted to spend for a short block 305 haha.. at one point I paid $250 for a running L98 350 long block..
            I have an Edelbrock Performer Carb intake I'll let you have cheap.
            1988 Trans Am GTA 355 TPI/700r4 Summer/Fall Driver
            2001 Nissan Pathfinder V6 4x4 Loaded and Rusty Winter Beater
            Always Missed
            1999 VW Passat 1.8T/5-speed
            1996 VW Jetta VR6/5-speed
            1988 Mazda 626 5-speed 300,000 miles
              Yeah problem is I have too much into the heads.
              I can meet you half way for delivery too if that helps, but still up to you lol
              91 Firebird 305 TBI
                i have a set of 416 heads for jons motor if that helps with anyones sale, they need to be redone but valves and cleaning is cheap, and jons fairly close to me
                00 Tahoe Z71........Stock
                  otherwise last time i asked for a 350 on greatlakes 4x4 i instantly had about 5 people with them still in vehicles for under 100 if i went and pulled it or 130 if they did and so forth.
                    Actually that's the same set of heads I have. I just have too much into the purchase of them to let the block and heads go for too much less. I'll work out a delivery plan with you though, cause I have a truck. So I have the block, oil pan, crank, pistons, rods, rings, flywheel, cam, 416 heads. What the engine needs is gaskets, lifters, push rods, rockers, possibly timing cover (I think I have a new timing chain set I can put on it) and you'll be all set for this engine. Heck, I'll build it for ya if you want to work out gasket/valvetrain stuff.
                    91 Firebird 305 TBI
