subframe connectors
  • subframe connectors
    Looking for some vert subframe connectors for a 97 maro.
    If you can't locate a set here, then get these from UMI:
    http://www.lmperformance.com/513903
    They also have a two-point set that are $200 bucks cheaper, but these are the best convertible ones on the market that I know of.
      I have bmr round weld in.ones
        Yeah those 3 point are pretty pricey. how big of a difference did they make in your car
          They made a pretty significant difference, and I've been toying with the idea of upgrading to the 3-point to help strengthen the chassis against our shitty Michigan roads.
            After what we put the rusty 500,000 mile camaro through at the mounds ORV park... I actually have a lot of faith in these chasis's. Granted that wasnt a vert, but that frame took a lot of hits before it finally buckled.
              Verts are a whole different ball game, mine flexed like a high school gymnast before the SFCs
                I found a set of the SLP 3 point SFC's on craigslist. You can definitely feel a difference. Should be the first mod on any vert. UMI decided to remake them a couple of years ago when nobody else was selling 3 points. They are better, in my opinion than my SLP's due to how they triangulate better. worth the money
                When in doubt, Whip it out !
                  I was really hoping to find some used ones. But it's not likely I will.
                    Look at LS1Tech.com or do a nationwide search on craigslist with SearchTempest.com
                    Just make absolutely sure that you are getting the convertible version. I'd hate to see you get stuck with hardtop ones with no way to get a refund.
                    Also, if you plan on using the weld-ins, you'd better pull your carpet because some guys have set their cars on fire by leaving the carpet in place.
                      Pulling the carpet is not an option. You can assume that it WILL set on fire if you dont.
