Driveshaft for short tail th350.
  • Driveshaft for short tail th350.
    It should be the same as a th200c out of an 82. I believe the measurement is 49.5 u joint to u joint. I need the driveshaft like yesterday...
    I have one I removed from a 1982 camaro that had turbo 350. Center to center or U-joints is about 44" I also have the longer torque arm.
      how much do you want for it bri? and can i get it tonight? i dont need the torque arm ans i have a tunnel mount
        and do you know if that had a 6 inch short tail shaft or the 9 inch tail? and its almost impossible to find a solid measurement online for a shaft! i got the 49.5 from numbers ive found but ive found other numbers that put my length at 44.. ive read the stock driveshaft in a 4thgen is 41.5 inches add 3 inches because the th350 is 3 inches shorter, and you get 44.5... but then i read the stock driveshaft is 44.25 inches long. which means i need a 47 inch shaft, then i also read the 200C driveshaft is a direct bolt in... and someone posted that it was 49.5 inches ujoint to ujoint...
          Sorry, I didn't see the response till now. Can you get the measurement from the pinion to the tailshaft? I MIGHT be headed north tomorrow afternoon. else I will be around all weekend. I can also measure an overdrive 3rd or 4gen driveshaft tomorrow
            Total length I need is 44.75 ujoint to ujoint. So that 44 can get me by till the shop gets my other shaft done. I called Midwest chassis and they said the 44 would get me by. I have a race on Sunday so I'm trying to get one ASAP. When you see this text me at 9897144985 thanks a ton. FYI I'll also be up all night working on the car
              eh id get one made before you race especially since most stock shafts run out in the middle and both weld yokes like crazy.
              00 Tahoe Z71........Stock
                for the record we had the shaft cut at 43.75, fits good, so the 44 would have been perfect too! drive shaft cost me 600 dollars.
                  WOW! I would sold it for a 1/10th of that.
                    price sounds about right.
