LS1 4L60E tranny pan wanted or prices on LS1 M6?
  • LS1 4L60E tranny pan wanted or prices on LS1 M6?
    dropped the pan on my tranny today to put a couple updated parts in the valvebody. good news, i fixed my lockup issue and the bigger boost valve seemed to make a huge difference. bad news after the car sat for a couple hours, it left a huge puddle of trans fluid. problem is the pan on this thing has been on and off so many times, its done. i replaced the cork gasket but the bolt holes on the pan are pretty damaged. with my stall im looking for a pan that will help try and keep temps down with a drain plug preferably. beggers cant be choosers although and if i have to settle for a stocker for the rest of the season so be it.
    on a side note im fed up with the A4 and would like to find an M6 and necessary parts for the swap. ill even consider an M6 thats needs rebuilt if the price is right. was running 11.80s consistently last year and once this year on a hot day. with the new LS2 and other mods performed recently i think ill be needing a roll cage soon enough and im not doing that so id rather something i could relearn and have more fun on the streets and possibly get back to needing a rollcage someday.
    lmk what you have or any suggestions on solving my current issues. any ideas on a good pan i could buy from a website or such. also the "built" A4 could be up for sale soon if i can get an M6 lined up
    thanks
    - - 5.3/4L80e/T7875 - -
    - Huron Speed Turbo Kit -
    1998 Formula
    Guess who has a stock pan that has been sitting in the garage for 6 years?
      what u want for it larry? itll get me by for now
      1998 Formula
        3.5 million...
          will pick it up this weekend if your schedule permits
          1998 Formula
            I will be in Bailey tomorrow at 1..
              ill take that off your hands larry. it will do for now. thanks!
              im still looking for an upgraded one and still wanting an M6 although.
              1998 Formula
                I had a TCI pan on my old Formula. Held a couple extra quarts and had a drain plug. I'd check one of those out
                2015 Silverado
                  i hate cork gaskets. what did you torque it too?
                    I have a chrome pan with a drain plug,has some scratches on the bottom of it...I used it on a lt1 4l60e...not sure if that matters..it held 1.5 extra qts of fluid...25.00
                      just hand tight. didnt really torque it. i hate the rubber gaskets. cork or the paper ones usually work best for me
                      1998 Formula
                        Mike be prepared to drop at least $2500 for an m6 swap.......start pricing stuff out, it's not cheap.
                        2000 Formula
                        fixed slow junk
                          Aaron (trymeh) has a ls1 6speed 4-sale pretty fair priced. he wrecked his car you may be able to get his whole setup.
