Does anyone fix bent rims? Or know of a good place that does?
  • Does anyone fix bent rims? Or know of a good place that does?
    I need to have a 15" aluminum rim fixed.
    Any help is appreciated
    1996 Base Model
    +2 cylinder mod
    Hey John,
    Check this place out!
    http://www.weldcraftwheels.com/
    2013 Stage II Nickey Camaro Convertible #10
    Special Edition
    Red Magnuson Super Charger w/a rear cog drive, ZL-1 fuel pump, Nickey cnc ported heads, Nickey spec. custom grind cam, Roto Fab CAI, Kooks LT's, No Weeds dual mode elec. diverters, Pedders eXtreme XA Coilovers, Pfadt ZL Spec sway bars, 20" AR Torq Thrusts wheels w/ polished billet Nickey centers, Nickey pistol grip shifter, upgraded 1400hp rear axles, 800hp @ the crank, 670RWHP w/613ft. lbs. of torque @11 lbs. boost! Check out album for pics!
      +1 Weldcraft
      88' Trans Am 350 TPI
        MAIN STREET WHEEL & TIRE is who we use here at work 1-800-728-8300 they're local
          Weldcraft is the only place I'd go. They do great work!
            If the wheel is replaceable I would just buy a new one. You are going to spend quite a bit of money to get one fixed. I looked at getting my z/28 wheels done and the cheapest I found was $125/rim.
            -Homer Simpson
              They're not replaceable.
              They're Alustar rims, kinda hard to find here.
              With the help of an instructor, I got it back to where it was supossed to be.
              Only the lip was bent, still held air fine.
              We used a half moon shaped block, brass hammer and some heat. With a few taps it went back into place.
              1996 Base Model
              +2 cylinder mod
                Originally posted by Bowtie-Bri View Post
                Hey John,
                Glad to see you got it fixed locally though, and probably for a lot less!
