Lt1 injectors
  • Lt1 injectors
    I need some 30lb injectors for the camaro,I am taking the car in next week for the tune and I need to get the injectors before I take it in..cash in hand...price,location,and miles on them please...Thanks
    i'm pretty sure ls1 and lt1 are interchangeable.. someone correct me if i'm wrong.. but i have a set of 42lb injectors with 3-4000 miles on them for 225. they worked perfectly when i put the camaro away this fall.
      all injectors with ev1 connector are plug and play
        Plug and play but I think they flow at different rates depending on lt1 or ls1, no? I vaguely remember something about LS1 injectors but if you put it in a LT1 it'll flow at a different pressure?
          I dont need 42lb injectors...I need 30lb
            never know what you might need down the road! haha
              injector flow rate is based off of a given fuel pressure. the higher the pressure the more they flow. LT1 fuel pressure is 3 bar, LS1 fuel pressure is 4 bar
                Yeah I installed LT1 injectors on my TPI motor.
                My stock was 19# 350's had 22# and with the LT1's pushed it up to 24#.
                With an AFPR.
                Maybe different years were different, I'm not sure.
