Need a 3rd gen Posi, Limited Slip, Etc Rearend. 9 bolt or 10 bolt dosent matter which. Must be 3.70 or lower(numaricaly higher) Gearing. Must be in good working condtion. Prefer disk brakes if possible but not a deal breaker. Let me know what you got. Looking to spend up to $300.
I have a 9 or 10 belt rear, cant remember, with drums. The ring is bad so you can install whatever gear you need. Has a very expensive posi unit with splined axles. let me know if youre interested. $80.00 Have paperwork on the posi and axles..
I have one I'm gonna be selling here shortly. 3.42's with 28 spline axles, torsen posi, set up for LS1 disks with an aluminum cover/girdle, also has relocation brackets welded on. The gearset whines (GM gears) so it needs to be rechecked. I also have a set of 3.73 motives for it.
Urgh, I am afraid to ask cause I already want this so bad... But how much are you or would you be looking for it?
