I need a radiator for a 97 camaro z28,for an automatic,i need this asap..
Radiator
you can use any radiator for camaro or trans am from 93 to 97 auto setup, i dont have one but you can use one from a v6 car with minor mods as a quick fix, i did on mine for the first few weeks till i could find a good used one.sigpic
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Brian has a v8 rad. its for a stick though. can use external trans cooler.sigpic
Yup to both above. 93-97 automatic transmissions are all identical they only changed how the hoses routed from the radiator... but the actual hookups on the radiator are exactly the same. If you want a manual one, I've got one here. It's missing the radiator coolant level sensor and you would need an external trans cooler for it but I'd let it go pretty cheap.- Brian Meissen
