Rocker arms
  • Rocker arms
    I need some rocker arms I perfer rollor or atleast roller tips let me know 3/8 1.6 thanks 586-430-1233 or pm me
    sigpic1999 Trans Am Bolt On Car plus Nitrous!
    2009 Yamaha R6
    ive heard some icky things about the comp rockers, i have harland sharps. do some research kid
      Runnin' Sharps myself. They had to make them, but it was well worth it.
        meh.. i'll stick with the stock ones. i dont plan on exceeding 7krpms
          agreed
            I dont think we are on the same subject I need to buy some rocker arms I switched out my cam and heads on my 383 carbed engine and in the instrucions it said do not use stock rocker arms and I dont want to spend another couple of hundred dollars if I dont have to so if some on has a set they are not using I will buy them
            2009 Yamaha R6
              Hey I was surfing craigslist and found these, dont know if they are exactly what you are looking for but I thought I share the link with you. http://detroit.craigslist.org/pts/1125155998.html He's asking $200 but I am sure he would take less if you offered him cash...
                Thanks I just left him a message and port huron is only minutes away from me by the way do you have any specs on that speaker box I would like to put one in my car once this engine install is done
                2009 Yamaha R6
                  Yeah I have a PDF file with all the specs to build that box, just PM me your email address or post it here and I can email it to you. For some reason it wont let me attach the PDF file.. Good luck with those Rockers I hope its what you were looking for!
                    well yeah you can do that you have a LS1 motor.
                      Agreed. The only reason I would run aftermarket rockers is if I was running aftermarket casting heads like ETP and TFS that require shaft mounted rockers.
                        There's a guy on EBay with a set of Crane 1.6 for 40 bucks and no bids. just type it in and it'll show 'ya
