Selling my Founders Performance single adjustable rear lower control arms. From founders website:
1982-2002 Camaro or Firebird Adjustable Lower Control Arms
Replace those weak, factory stamped lower control arms with Founders Performance extreme duty tubular adjustable arms. These are a direct bolt-on replacement that minimize wheel hop, improve cornering, lowers ET's and greatly helps your track consistency. The chrome-moly heat treated spherical rod end allows your rear suspension to be bind free which makes these a great upgrade for both your track and auto cross driven car. We designed these to have the polyurethane bushings bolted to the cars chassis for a quiet comfortable operation. Founders Performance control arms are constructed form U.S. made DOM mild steel tubing 1.250" OD x 0.095" wall, 1045 steel threaded tube adaptors (stronger than chrome-moly), completely CNC machined and fully pulse welded for outstanding strength. Founders control arms feature Energy Suspension® polyurethane bushings, zinc plated steel sleeves and "on-car" grease able grease fittings. Adjustments are easily made with the high quality Kevlar/Teflon lined spherical rod ends for a quiet bind free performance. Control Arm Features:
23962SA Single Adjustable Lower Control Arms Features
1.25" x 0.095" DOM Mild Steel Tubing
1045 Steel Threaded Tube Adaptor (stronger than chrome-moly)
¾" Hard Chrome Plated, Teflon/Kevlar Self Lubricating Race Rod End
High Frequency Pulse Welded Construction with Rosette Welds on the Bung Side for Extra Strength
CNC Machined Step Bushings with Proper 12MM ID for use with Factory Bolt.
Energy Suspension Fluted Polyurethane Grease-Able Bushings
Designed for Proper Use of the OEM Hardware
Installed Grease Fittings for on the Car Maintenance.
Standard Red or Black Powder Coating for a Great Looking Long Lasting Finish.
Improves Responsiveness and Control
MADE IN THE USA!
These were on my car for less than 1000 miles, still in great condition. Will include the mounting hardware. Brand new with the hardware and shipping these cost me $142.53.
Only asking $100.00 plus shipping.
PM here or email to meenz28@msn.com.
MADE IN THE USA!
