1968 Camaro-454 engine-run's 11 sec qtr mile times-still streetable
  • 1968 Camaro-454 engine-run's 11 sec qtr mile times-still streetable
    1968 Chevrolet Camaro, qtr mile times in the 11 second range. Canary Yellow, black int, 454 engine, 850 Holley double pumper, with 4-corner idle system, 288 roller cam .623 lift, Manley Valves with 3 angle, Harlan Sharps roller rockers, Dart-Merlin Oval port heads, short-block was blueprinted/balanced, 10:1 mech compression, Forged TRW pistons, plasma-moly rings, ARP rod bolts, Fed Mogul HX rod/main bearings, ARP main studs, 7 qt Moroso oil pan with baffles and windage tray, hi-volume oil pump, Weiand Team G Alum Intake gasket matched to heads, B&M shifter, MSD 6AL ignition and distributor, 2-stage rev-limiter, MSD rich/lean indicator, Hooker Comp headers, tilton super-starter, fluidamper, T400 transmission-manual valve-body, 3,500 rpm stall, 4.30 gears, locking diff, M/T tires (slicks with tread) 29x12.50 rear, 16 gal fuel cell mounted in trunk, electric fuel pump, dual 3” exhaust, newer Diehard battery in trunk, new power steering pump and serpentine belt setup, Griffen Alum radiator, large dual cooling radiators for trans fluid. Removable roll cage for drag racing, but car is streetable. Autometer guages and tachometer. Ladder bars with floating housing mounts on rear axle with leaf springs (not tubbed), with frame connectors, solid body, engine and trans mounts, 90/10 shocks front, 50/50 shocks back. Paint and interior in decent shape, no rust, but not a show car. Has RS grill, not original, (1 of 2 motors for headlights work). Also have extra set of T400 trans guts and many carb tuning parts/gaskets. More performance details too numerous to list. $16,500 OBO. Call Roy at 269-470-2478, leave message. Email: remaster3@yahoo.com
      what he said
        sounds cool, put pics up
        1996 CAMARO Z\28 M6
          Looks like a nice Camaro. Good luck selling it, I don't know how many people on here can afford that though.
            Post more pics when you get a chance. How bad is the car cut up?
              wow super sweet car!!! I like it alot!
                Nice Camaro,good luck in selling it.
                **** FEAR THIS ! ***
                  Sounds like a perfect car for James.
                  The first Gen started it all!!!
                  67 CAMARO RS AND A SEXY WIFE
