Real SLP Firehawk #623 with documentation
Clean MI title
76000 original miles
Charcoal interior/leather
$15999
ENGINE:
Katech Torquer LS3 engine
-Brand new LS3 crate engine
-Katech Torquer LS3 cam
-PSI springs
-Titanium retainers
-CNC-ported heads
-C5-R Timing chain
-Katech rod bolts
-Set up with 24x/2x triggers & 90mm cable throttle body to run on 1999 PCM.
-Powdercoated red valve covers
-Paint matched intake cover
-Katech billet belt tensioner
-Brand new f-body damper, water pump and oil pan
-Engine dyno tested 538hp/495lb-ft
-SLP lid with new K&N air filter
-Pacesetter ceramic coated headers
-3" Spin Tech exhaust - sounds amazing
DRIVETRAIN:
New LS7 clutch
Hurst aftermarket shifter
New OEM Hurst leather knob
New slave cylinder
Tick adjustable master cylinder
3.90:1 rear axle
FUEL SYSTEM:
Racetronix fuel pump
SUSPENSION/BRAKES:
Subframe connectors
Adjustable torque arm
Tubular rear control arms
Control arm drop brackets
Adjustable rear shocks
Drilled/slotted rotors
Fresh alignment and new tie rod. All other suspension inspected - ok
WHEELS/TIRES:
Chrome Firehawk wheels
Brand new BF Goodrich Comp G tires
PAINT/EXTERIOR:
Complete paint job by premier MI body shop, Autometric
Looks better than it did in 1999. Pictures don't do it justice.
Satin black rear diffuser and license plate area
Fresh 5% tint on rear glass. Looks like about 25% on the front
Brand new windshield
Clean MI title
$15999
ENGINE:
-PSI springs
-Titanium retainers
-CNC-ported heads
-C5-R Timing chain
-Katech rod bolts
DRIVETRAIN:
New LS7 clutch
New slave cylinder
3.90:1 rear axle
FUEL SYSTEM:
SUSPENSION/BRAKES:
Subframe connectors
WHEELS/TIRES:
PAINT/EXTERIOR:
