Won't let me. When I hit submit I get this... "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'A!!!', '248-231-9185', '1999', 'Pontiac', 'Trans Am', 'Black', '-LS1 -6-spd -T' at line 1"
Can't register for M&G
Tom didnt you know you got banned and are not allowed to go?
I just tested and it's working fine. But, you're putting "A!!!" into one of the fields - what field is that? What information are you putting into the fields?Originally posted by ITSSLOW View PostWon't let me. When I hit submit I get this... "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'A!!!', '248-231-9185', '1999', 'Pontiac', 'Trans Am', 'Black', '-LS1 -6-spd -T' at line 1"- Brian Meissen
what did you do?
