As the title says i screwed with it, it doesnt run anymore and im out of ideas. 92 camaro 3.1L
Originally it was lacking alot of the already low power range, and was misfiring. plugs cleared that up alot, fuel filter and air filters helped after that, once I replaced wires it would idle 10x better but in gear it would die, just start missing terribly and die. delco wires, ngk plugs. I put everything back together as it was previously one wire at a time. Before that issue I checked timing it says its at 20* with the esc unplugged. I cant check it now because it doesnt run at all. so to the chiltons I went, it told me drivers side was 135 pass side was 246 and firing order was 123456. same thing it would idle all day but in gear it wouldnt run whatsoever. I contacted a friend who corrected me that cylinder on the pass side were 135 and drivers were 246. once again it would idle but die under load in gear. Back to square one pull the cap, line the timing marks up which id assume would put cyl 1 at tdc again. Started the firing order with 1 and went through it all over and I cant even get it to start now. I'm so lost. fuel pressure checked out fine and didnt diminish after sitting when I did fuel filter. What am I missing here? Seems to be a bunch of misinformation out there as to whats what between the gm and buick 3.1 which are apparently entirely different.
More info on the car which may or may not be of use. It has a hypertech chip, i know its junk but it ran great before still should run ok, as well as a cam. I assumed some of those 20* of timing may be due to both of those but i think 20* with esc unplugged is still ridiculous. I was attempting to get it running better to just drive it, focus on interior and suspension until i have a SBC all together ready to drop in down the road.
