are manual and automatic crossmembers the same for a stock 5 speed or 700r4? if not does someone have the crossmember for an automatic car?
thirdgen trans crossmember
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
97 K1500 lt4 cam, 1.6s, MPFI, Solid axled, IROKs,------winter beater -
Originally posted by bri2203 View PostI believe they are the same but I would have to check. I have 3 or 4 of them
what he said, I believe they are the same.
- Greenville, MI
- Die Maker
Some had the weird crossmember with the secondary crossmember setup.
I used the same crossmember when I went from 700r4 to T5
- 3000
- Tyler Porter
- student
all the bolt holes line up i know the mounts are the same but the 700r4 doesnt push the crossmember back or forward at all or vice versa?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
- Greenville, MI
- Die Maker
Nope, same everything.
- 3000
- Tyler Porter
- student
great! thanks Guys!91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
