side marker ????
  • side marker ????
    Anyone know how I can replace my sidemarker bulb for the sidemarker in the front fender. I can see it but I can't get to it. Is there someway of getting at it underneath the car?
    yes pop your hood and u can get down in there up in the front. its rather simple. just look under the fender liek by the battery and you should be able to see it
      I can see it, just through a really small hole, and I took my battery out to see if I could get it but I couldn't
        Isn't there a torx screw on the lense itself you can remove and pull it out that way?
        Wade
          not on mine its held in by two clip type things. you should be able to get underneath and slide your arm up in there and get it
            3rd gens are inside access only.
            Unless modified.
            Either pull your headlight assembly or
            pull the (3) bolts on the ground effects on the underside of the car.
            Reach up and then turn the bulb connector and pull it out.
            Then pull the bulb out.
            Definitely not a 2 minute job.
            But not an hour long one either.
            BTW... Let us know how it goes.
            Currently Owned F-Bodies
              I think the rears have screws and the fronts have clips
              1995 TA Sold. i sure do miss it though.
              1998 Trans Am aka Winter beater
                From the inside of the Quarter.
                  yep from the underside is basically the only way. The socket just twists out and the bulb pulls out of the socket. I think it is a 198.
                  -Homer Simpson
                    oh thanks but i already found that out, yeah and i've gone through 3 bulbs already and none have worked, same with the back left, both on the left side will not come on or flash. Any one know what could be wrong??
                      Bad Socket.
                        Time to pull out the old Volt Meter..
                        Start a tracking.
